fast idle valve
so i have a 95 civic hatch with a d15b, i picked up a p32 intake manifold (d16z6 manifold) i go to hook everything up and the hose that goes from the bottom of the fast idle valve has no where to hook up on the intake manifold. this **** sucks. how do i go about fixing this problem? thanks in advance
it starts at a L shaped hose at the intake manifold, and from there it moves through a metal tube to another hose which then goes to the inlet of the fitv. after leaving the fitv it goes to the iacv. once leaving the iacv it drops down and connects to the coolant pipe on the back of the block.
yes thats what i would do because its pointless if u live in warm climates. just by pass the tb and run the lines to ur iacv. ebay acually makes block off plates b/d/f/h all fit
RiversideS13
Jul 18, 2007 11:08 AM
importimage
Jun 14, 2003 10:46 AM
