96 Civic LX Radio Wiring Issue
Old 09-14-2012, 11:24 AM
Ephemeros's Avatar
Default 96 Civic LX Radio Wiring Issue
So, I've been in the process of straightening out issues this car came with when I got it, and I've been living without a radio for a while which is starting to **** me off. The previous owner said the radio stopped working and was pulled. I discovered the radio fuse was popped and took it out.
This, however, is what the wiring harness looks like:
https://i.imgur.com/KYet3.jpg
The car does NOT have keyless entry, so I realize one of those connectors is probably superfluous. I do not know which one I'm meant to connect an aftermarket adapter to, though. I also don't know if those loose wires on the right mean that a connector was yanked off, but I sure hope not because that would mean I'd have to deal with those wires individually.
...help?
Old 09-14-2012, 11:40 AM
The Grumpiest
grumblemarc's Avatar
Default Re: 96 Civic LX Radio Wiring Issue
You have no audio connector anymore. That mess of cut wires is all you have left.
Old 09-14-2012, 11:56 AM
Ephemeros's Avatar
Well that's just ******* great. I guess I'll have to take the dash off to work on them. I'm assuming they're color-coded and I can find that info in the Honda manual?
Old 09-14-2012, 12:01 PM
kyden's Avatar
here's the wiring chart.
http://www.the12volt.com/installbay/...tail/1049.html
i love how cheap or dumb some people are. why cut the connector off when you can get an adapter harness for under $10? bunch of hacks.
i am surprised none of the exposed wiring has grounded out and popped a fuse.
Old 09-14-2012, 12:26 PM
Ephemeros's Avatar
Well, the fuse WAS popped, so...
Sigh. How big of a pain in the *** is it to get the dash off this car? There's some other stuff I need to look at in there anyway so I might as well get it over with.
Edit: Looked it up and I guess I don't need to take out the whole dash, just the cluster with the vents and climate control. That won't be too bad. I do need to replace my instrument cluster lighting or see what the hell is wrong with it anyway. The fuse was popped, I put a new one in and it worked fine for a while and now it doesn't even though the fuse is still good. WELP.
AustinGT
03-29-2019 07:48 AM
j4s0n1337
05-24-2011 05:04 PM
RedHurricane
Audio / Security / Video
01-31-2011 09:51 PM
nbcivic
10-03-2010 06:51 PM
peterislazyek9
06-12-2007 11:45 PM
Quick Reply: 96 Civic LX Radio Wiring Issue
