Windshield Wiper Issue
I have a '98 Civic EX and it appears the windshield wipers have developed a mind of their own. They are constantly on regardless of the switch position. I replaced the controller switch assembly and that did not solve the problem. Anyone have anything like this happen? Any suggestions on what to try next?
Is the motor running at high or low speed?
Use your multimeter to check for a short to ground on either the BLU/YEL wire (high speed) or the BLU wire (low speed) running between the motor and switch.
Tape or replace the damaged portion of the BLU wire that is causing the short. Also consider that the short may be occurring at either end of the BLU wire (i.e., in the motor connector or the switch connector). Therefore, inspect the BLU wire terminals in the connectors for damage.
Coming from the wiper motor, right? You should see three blue wires: BLU/YEL (thin yellow stripe), BLU/WHT (thin white stripe), and BLU (solid blue no stripe). You want the BLU wire.
neast70
Sep 26, 2021 09:48 AM
