Help with 2 step activation button...
Old Aug 9, 2003 | 11:59 AM
hybridreams's Avatar
Default Help with 2 step activation button...
The top half is the on/off switch I used to use to activate my rev limiter. Worked good, but kind of a hassle to have to flick off when launching.
The bottom half is the push button switch I just bought. It doesn't say which plug is for what (just has that, "H"). I tried hooking up the ground wire and the wire from the ignition to the two plugs on the new switch, but the rev limiter wouldn't work when the button was pressed. I even switched around the the ground wire and wire to the ignition box just in case I hooked it up backwards, but I got the same results.
What's the deal? Am I connecting it wrong?
Old Aug 9, 2003 | 01:15 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Help with 2 step activation button... (hybridreams)
i dont think the ground wire is connected to the switch. I forget offhand. one wire should be the 2step wire, and the other should be 12v. H is for hot, so put the 12v to that side. HTH
Old Aug 9, 2003 | 07:57 PM
no2psi's Avatar
test for continuity across the new switch when the button is pressed.
Old Aug 10, 2003 | 10:23 AM
Default Re: (no2psi)
How do I do that?
Old Aug 10, 2003 | 06:22 PM
B18C1 for fun's Avatar
Default Re: (hybridreams)
Hey kid, I'll do it for you if you gimme your rims for $400. LOL...jk...the MSD box needs a 12V input to activate the 2 step. So all you need to do with that switch is put one side on to any 12v source and the other side to what I believe is the pink wire on the Digital 6.
patpeery
Apr 1, 2008 07:52 AM
standbackimapro
Audio / Security / Video
Feb 21, 2007 07:38 AM
Want2race
Jan 14, 2003 12:51 PM
civic817
Sep 26, 2001 07:10 AM
