altenator plug
Old Jun 9, 2009 | 10:47 AM
rick_rabies's Avatar
I'm not Rick!
Default altenator plug
my friend Chang mong wants to know if he can switch his altenator rather than cut and switch altenator plugs. 98 civic that had y7 now obd1 gsr motor
And will and obd2b SI harness work for his motor if we got an obd2b to obd1 conversion?
Old Jun 9, 2009 | 11:30 AM
I'm not Rick!
Default Re: altenator plug
anyone? obd1 gsr in ek
Old Jun 9, 2009 | 12:19 PM
Cortez_h's Avatar
Your trying to use a obd2b SI harness on a obd1 gsr motor? No that won't work...since the dizzy, alt. plugs are different and I believe all obd2 motors have a knock sensor. The obd2b to obd1 conversion harness just makes it so you can use a ob1 ecu.
Old Jun 9, 2009 | 12:29 PM
I'm not Rick!
yes..thats what we want to do..obd2b to obd1. conversion harness and obd1p28. and we can get an adapter from rywire for the dizzy. im asking if the altenator from a D series will bolt to the gsr motor and work fine?
Old Jun 9, 2009 | 02:44 PM
R666_EK's Avatar
The D series won't bolt up. Just get an obd2 B series alternator. Or swap the harness plug.
Old Jun 10, 2009 | 05:25 AM
I'm not Rick!
i tried the plug swap, but wires on both ends are dif colors. so i matched pinouts. just real getto like
Old Jun 10, 2009 | 06:07 AM
bigD's Avatar
Just so you know you did not need to cut any wires, the plugs on the alternator itself can be swapped out. Just pop the cover off and unscrew it very easy to do
wing.jai
16
Dec 3, 2008 01:09 PM
94eh2
Jun 23, 2007 09:51 PM
Tacoma Luda
May 9, 2006 07:20 PM
GSR619SD
Jun 11, 2004 10:10 AM
TURBOED-TEG
Sep 14, 2002 02:28 PM
