B16 Block GSR head Question
Old Jun 6, 2009 | 07:36 PM
aeenox's Avatar
Default B16 Block GSR head Question
Ok I bought a crx about 2 weeks ago. And the engine in the car is a b16 block with a GSR head. So why is the engine set up like that? What are the pros and cons about it?
Old Jun 6, 2009 | 07:57 PM
stevenDAtegra's Avatar
Default Re: B16 Block GSR head Question
hhmm well
Things off the top of my head are
pros
*Higher compression
cons
*less torque
*Not as good as flow
Old Jun 6, 2009 | 08:06 PM
aeenox's Avatar
Then should i get rid of the GSR head and buy a b16 head
Old Jun 6, 2009 | 08:07 PM
Str8EJ's Avatar
what kind of intake manifold? is it a p72, and if so, are you using a gs-r ecu?
if there's a way to make the two-stage intake work on that little super-rev'r motor, may be there's a way to compensate for the lack of torque.
more compression for sure.
Old Jun 6, 2009 | 08:12 PM
aeenox's Avatar
I have a p72 head with a JG intake manifold. But im not sure wat ecu is on the car. imma check tomorrow
Old Jun 6, 2009 | 10:27 PM
b20blkcivic's Avatar
No, Just keep it. Thats the same setup that I am running on my Turbo Si. GSR Head B16 block making 402Hp @ 19psi.
Old Jun 6, 2009 | 10:42 PM
here is my Dyno too.
Old Jun 6, 2009 | 11:38 PM
aeenox's Avatar
But i wanna built a N/A motor. Would it still be a good idea to keep it??....cause i want built the enigine. Is there more people running this setup???
Old Jun 7, 2009 | 01:20 AM
This is good for all motor right now because you have high compression. what b16 block do you have? If it's a b16A with a GSR head, that compression will be crazy. Also, what transmission is on the car?
Old Jun 7, 2009 | 01:48 AM
Ruben19's Avatar
is only .02 compression higher from the b16 head if your using stock internals.
let say b16 block & head compression ratio is 10.1
then with gsr head is 10:3
Old Jun 7, 2009 | 03:14 AM
gibsanez's Avatar
FALSE FALSE FALSE FALSE
When will the misinformation about the GSR head stop? The difference in flow is NEGLIGIBLE.
Old Jun 7, 2009 | 04:56 AM
00Red_SiR's Avatar
All Motor Mentor
stevenDAtegra- stop posting, you obviously have no idea what you're talking about.
b20blkcivic- he's running N/A not boost. While your setup is impressive, it really has little to do with his setup.
The GSR head gives a .2 bump in compression only. It's port design tends to give better transitional response and a combustion chamber that is less prone to detonating etc. The GSR head is a good head and there's no need to remove it from your engine.
The JG intake manifold may be a poor match to your engine if it's a similar design to the Victor X style. Another style of intake manifold might be better especially if you have cams. You'll need some type of engine tuning system to really benefit from any mods though.
Old Jun 7, 2009 | 09:08 AM
MadVTI's Avatar
I found that with stock bottom end, your pistons rub ur head after 9000rpm due to the stretch in the rods! I had skunk2 stage 2 cams and a built head and revved it to 9300rpm. I think it was due to not having the 0.015" indented areas on the gsr head that the pr3 has cast in? Just be aware thats all matey, i had two big end failures from this. Marc
Old Jun 7, 2009 | 12:03 PM
killerpenguin21's Avatar
^^^lol
you ran a b16 piston/rod into the head with those tiny cams? me thinks you had some other issue when the motor was assembled. or a very weird combo of parts.
did you ever measure p2v before you put it together?
Old Jun 7, 2009 | 12:15 PM
numberone's Avatar
Why would you rev a stock bottom end to 9300 rpm?
Back to the point. Your gsr head is fine, ditch the IM and get a skunk of blox IM. Good day.
Old Jun 7, 2009 | 06:05 PM
aeenox's Avatar
Ok cool cause i have a b16a block and a p27 head. I looking to trade the JG im for a skunk2 or blox one But i need the person who trades me to install the mani too.
Old Jun 7, 2009 | 06:31 PM
all-mtr-teg's Avatar
hhmm well
pros
*Higher compression
cons
*less torque
Please explain why a gsr head would have less torque and flow vs. a b16 head.
Old Jun 7, 2009 | 06:40 PM
they wont he is incorrect.
Old Jun 7, 2009 | 07:34 PM
aeenox's Avatar
Then wat kind of mods should i try to do? Just treat it like anyother swap or should i foces more on the head or block? Imma go get it tuned because it prob isnt tuned yet.
Old Jun 8, 2009 | 12:40 AM
Conan the Destroyer's Avatar
this thread is effing awesome.
Old Jun 8, 2009 | 05:12 PM
aeenox's Avatar
so wat would work better with this set up a b16 tranny or gsr tranny??
Old Jun 9, 2009 | 01:27 AM
gibsanez's Avatar
Better for what? Drag racing? Top speed runs? What's your goal Hp level? Auto cross?
Old Jun 9, 2009 | 08:34 AM
aeenox's Avatar
imma use my car for drag racing. my goal hp is 180whp
EgxHaTcHxGsR
Nov 22, 2009 10:51 PM
slowB20ej8
May 19, 2008 12:19 PM
anti muscle
Jan 5, 2005 06:02 PM
.ShawnD.
21
Jul 17, 2003 08:15 PM
CBR
Aug 19, 2002 07:18 AM
