Code 6 and Code 86 differences? Need some help
Old Jun 3, 2009 | 06:57 PM
BanEL's Avatar
Default Code 6 and Code 86 differences? Need some help
6 ECT - water temperature sensor
86 ECT sensor - Cooling System
i'm getting a code 6 on my b18c, but cant seem to find the correct info on which sensor it is.
the 1 by the lower rad hose, or the one under the dizzy.
and does anyone know where i can find schematics? i got the honda manual, and it has nothing on the water temp sensor.
Old Jun 3, 2009 | 07:13 PM
civic_driver's Avatar
Default Re: Code 6 and Code 86 differences? Need some help
Check the codes here: http://www.k-series.com/dtc.html
Old Jun 3, 2009 | 07:20 PM
Former User's Avatar
Under the distributor are two coolant sensors, a 1-wire sending unit for the dash gauge and a 2-wire sensor for the ECU. It's the 2-wire sensor that is throwing both codes.
Old Jun 3, 2009 | 08:19 PM
BanEL's Avatar
gotcha. found the sensor, Now, i've looked on the civic manual and cant find schematics for this sensor to the ECU.
some other info from fftechnet
http://technet.ff-squad.com/wiring.obd1.htm
pin out from ECT Sensor to ECU is "D13" does not have wire color red/white OR yel/blue.
and it does not ring out from ECT sensor to D13.
Old Jun 3, 2009 | 08:22 PM
BanEL's Avatar
oh 1 more thing. i jumped the ECT Switch on the thermostat housing, and the fan came on. so relay, fan etc are good.
Old Jun 3, 2009 | 08:33 PM
Yeah, the problem is with the Engine Coolant Temperature Sensor, not the switch on the thermostat housing.
Old Jun 3, 2009 | 10:02 PM
BanEL's Avatar
yea, no i figured that. But when the motor was pulled, there was no codes so i much rather check the wiring diagram first, before i go replacing sensors that where fine before.
Old Jun 4, 2009 | 06:07 AM
Sounds good to me.
eghatchfla
May 28, 2010 06:26 AM
ham
Apr 13, 2007 07:43 AM
mycrx7
Jan 23, 2007 11:21 AM
MIDNIGHT
Apr 12, 2003 06:27 PM
brian estrada
Apr 3, 2003 06:33 PM
