stock clutch
Old May 30, 2009 | 10:44 AM
98h22's Avatar
Default stock clutch
how long do you guys think a stock clutch will last on a boosted d16 running 10lbs?
Old May 30, 2009 | 11:01 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: stock clutch
not long. it may hold up but if you start driving aggressively, i dont think it will hold up.
Old May 30, 2009 | 12:02 PM
marcj's Avatar
it depends on your setup.. I have a stage1 exedy, and it was slipping bad at low rpm with my t3/t04e at 11psi.. I turned the boost down to 9psi and went with a bigger/laggy turbo and I don't have problems with it now. I would say upgrade asap though! there is nothing worse than having a setup capable of 500whp and a clutch that will only hold 250whp
Old May 30, 2009 | 03:22 PM
nfereorhatch's Avatar
My stock didn't last at all, slipped badly on the dyno at 7lbs 180hp.
Jax419
Jul 2, 2007 08:37 AM
Schister66
Dec 4, 2005 02:22 PM
Boosted_93_Si
Oct 12, 2005 07:32 PM
Btothe3rdDegree
Oct 3, 2004 12:54 AM
scooter
Jan 21, 2003 11:14 AM
