Wideband question
My buddy had an LM-1 kit but the bot itself with the readout and everything went out. If I bought an Innovative gauge would that plug right into the sensor or does it plug into the box? He think's he threw the main box away but I know he still has the wideband sensor. I'm running way low on funds and need a wideband still so I was wondering if this could help cut a corner. The only wideband I have used in an AEM and the sensor plugs into the gauge so can this be done with a Innovative sensor? Thanks.
the bosch wideband sensor will plug into a "box", which is the actual lc-1 controller. then there are output to run to a gauge.
so basically you cant just plug a gauge directly to the wideband, there is a middle piece which is the actual controller, probably the most imprtant piece
krysted9354
21
Dec 27, 2008 11:58 PM
