Bullseye power turbo on a D
Hey im looking for a BW unit for my D, Set up is as follows:
benson sleeves, Laskey built
CP pistons 76mm
eagle rods
Portflow Port and Polish
Bisi 1.2 turbo cam, and cam gear
3inch turbo back custom exhaust
mini ram mani w/ tial 38mm
Bout sums up the set up.
I need a turbo that is going to be good for 500-550#, but also decent on the street, will be running low boost while on the street. I have been recomended by Dan at bullseye to go with the 259 with the 70 ar, and i have also been recomended by a reputable D-series guy to go with either the 362 or 262.
I am just looking for more opinions on this.
Thank you.
CP pistons 76mm
eagle rods
Thank you.
Re: Bullseye power turbo on a D
what kinda of spool times would i be looking at with the 259? As of right now my GT2871R .86 ar i get full boost around 5200-5500.
does anyone have a compressor map for the 259? or is it the same as the 258?
also what can you guys tell me about the 262?
http://www.bullseyepower.com/S200.asp
The 59mm compressor replaced the 58mm if I remember correctly. The S262 would be basically a 62mm compressor matched with one of the smaller turbines, not a good combo.
Mr.Hankey
08-25-2006 10:56 PM
