Wideband question
Old May 29, 2009 | 01:17 AM
TwoKSiR's Avatar
Default Wideband question
My buddy had an LM-1 kit but the bot itself with the readout and everything went out. If I bought an Innovative gauge would that plug right into the sensor or does it plug into the box? He think's he threw the main box away but I know he still has the wideband sensor. I'm running way low on funds and need a wideband still so I was wondering if this could help cut a corner. The only wideband I have used in an AEM and the sensor plugs into the gauge so can this be done with a Innovative sensor? Thanks.
Old May 29, 2009 | 04:44 AM
dpetro1's Avatar
Default Re: Wideband question
the bosch wideband sensor will plug into a "box", which is the actual lc-1 controller. then there are output to run to a gauge.
so basically you cant just plug a gauge directly to the wideband, there is a middle piece which is the actual controller, probably the most imprtant piece
blackeg
Aug 12, 2016 04:52 PM
SWAT
Engine Management and Tuning
Jan 11, 2011 03:26 PM
krysted9354
21
Dec 27, 2008 11:58 PM
94dxt
Apr 22, 2004 10:35 AM
