93 del sol swap questions ?
Old May 25, 2009 | 04:01 PM
07jdmfit's Avatar
Default 93 del sol swap questions ?
i an looking for info i have a ls / vtec swap i am trying to find if i need anything else for it to work ,, also work correct , i have a gsr wire harness , gsr dizzy , gsr linkage , a virgin p28 , the rear b seriies mount braket , is there anything else that i need? also wondering if the ecu will work with the motor , , motor has a 11 to 1 compression ratio , type r intake cam , gsr exaust cam , its a b16 head , also the head has skunk2 springs and retainers , the motor is all arp bolt and stud , ,,sorry if any are dumb questions i have never done a swap so i figured i would ask
Old May 26, 2009 | 06:23 AM
buff1110's Avatar
Default Re: 93 del sol swap questions ?
search, search and search!
ecu will make the motor run like crap until its tuned, i would send it off to phearable.net and have them chip it
Old May 26, 2009 | 07:53 AM
1LowSol's Avatar
That, Or any Basic Tuner can chip and socket it... For like 60 bucks. Then you'll be ready for a tune.
Old May 26, 2009 | 08:36 AM
iwanttokillgod's Avatar
u have to make sure you have del sol dohc shift linkage integra wont work
Old May 27, 2009 | 10:15 AM
buff1110's Avatar
good call, the linkage and shift linkage stabilizer bar from a 94up del sol vtec.
Old May 27, 2009 | 03:37 PM
07jdmfit's Avatar
can you modify a gsr linkage set up to work?
Old May 27, 2009 | 03:59 PM
eglized's Avatar
no wont work dude jus get another linkage del sol
wolf95
38
Oct 20, 2009 11:13 AM
94_sol
Oct 31, 2007 06:06 AM
nekoabandoned
Mar 19, 2006 08:31 PM
bjfisher
Jan 8, 2006 05:44 AM
blake06_
30
Feb 28, 2003 04:39 PM
