93 del sol swap questions ?
i an looking for info i have a ls / vtec swap i am trying to find if i need anything else for it to work ,, also work correct , i have a gsr wire harness , gsr dizzy , gsr linkage , a virgin p28 , the rear b seriies mount braket , is there anything else that i need? also wondering if the ecu will work with the motor , , motor has a 11 to 1 compression ratio , type r intake cam , gsr exaust cam , its a b16 head , also the head has skunk2 springs and retainers , the motor is all arp bolt and stud , ,,sorry if any are dumb questions i have never done a swap so i figured i would ask
Re: 93 del sol swap questions ?
search, search and search!
ecu will make the motor run like crap until its tuned, i would send it off to phearable.net and have them chip it |
Originally Posted by buff1110
(Post 38666032)
u have to make sure you have del sol dohc shift linkage integra wont work
good call, the linkage and shift linkage stabilizer bar from a 94up del sol vtec.
can you modify a gsr linkage set up to work?
no wont work dude jus get another linkage del sol
