del sol swap info needed ><"
this has been talked about alot im thinking,but i need to know what all i need to swap a ls motor in to my del sol. ive heard things like all i need mounts wise was right motor and rear tranny mounts ,is this true? also im thinking that ill need del sol dohc shift linkage,long block,tranny,ecu,axles, what am i missing? please no SEARCH answers thank you, also only facts
Re: del sol swap info needed ><" (nekoabandoned)
ok, i just did a 01' gsr swap in my sol...i used all the gsr mounts(ls mounts same), i used the gsr wire harness(use ls harness), i did have to get a dohc vtec sol shift linkage (paid 130 @honda) the front tranny mount and front block mount i had to swap the bushings from sol to the gsr mounts..other than that i had a lil issue w/ ecu because of obd2( so check what motor your gettin (obd1-2), so while im waiting on my s100 p28 im just running a stock p28 just to drive it...sohc specs suk but if you get obd 2 motor you wil have to get a harness for ecu ..lol, hope it helped bro...oh yea and the obvious motor, tranny, axles, and others mentioned above....
90civichb
06-05-2004 04:13 AM
