Part number help (or direction)
Old May 25, 2009 | 10:14 AM
ThinkRevolution's Avatar
Default Part number help (or direction)
Hey, I know this is alittle obscure but I was hoping maybe someone can help me find part numbers, and tell me where would be a good place to order OEM equipment from?
It's a 1992 civic CX (bubble)
I need:
Oil pan drain bolt and washer
Oil cap
Oil pan gasket
(I have a couple of oil leaks I want to try to patch up, or at least 1 oil leak but I want to hit all fronts so it's something I only have to do once)
Thank you!
Old May 25, 2009 | 10:18 AM
kp's Avatar
kp
Default Re: Part number help (or direction)
Call your local dealer, or look on eBay. Oil plugs are common and cheap, you can order those anywhere. The oil cap can be bought from Honda but any brand should do the trick. The oil pan gasket is probably very cheap, even from honda.
I think you'll find that all of these can be bought for less then $35 from Honda. Call your dealer.
Old May 25, 2009 | 10:49 AM
deadazleep's Avatar
your looking at $40.30 for the parts listed shipped off of www.hondaautomotiveparts.com which is a excellent website for OEM parts. I'ld recomend bringing a printout of the parts and prices from that website into a dealer, thats the only way i've got a dealership to lower their prices to get my $.
Old May 25, 2009 | 07:31 PM
how did you find those parts? I just browsed through and can't even find the correct system.
Local dealers want part numbers is the problem ;(
Old May 26, 2009 | 04:09 AM
kp's Avatar
kp
I would bet that 95% of customers that buy parts from dealers don't have resources like this, that's why they go to dealers. If your dealer won't sell you parts without part #'s, they must not make very much money.
I can't find the right section either, I found your oil pan gasket but it comes in a kit with other gaskets.
Old May 26, 2009 | 06:41 PM
FJRguy06's Avatar
another source for part numbers is hondapartsnow.com.
Check this link (if it works...)
http://www.hondapartsnow.com/Page_Pr...PAN&appid=5945
Old May 26, 2009 | 07:23 PM
deadazleep's Avatar
Just go to auto parts and put in your cars info
then the drain pan bolt, crush washer, and gasket can be found in "cylinder block-Oil pan"
gasket is #6, washer is #36, and bold is #22
Oil cap is under "Cylinder Head Cover"
Cap and gasket #9
Site can be tricky, been using it so long i can normally find something random without taking forever like when i first found the site.
Old May 26, 2009 | 07:57 PM
Cap and gasket #9
awesome you rock. Going to order now.
Old May 26, 2009 | 08:25 PM
fastrxu's Avatar
at the pick-a-part you can get the oil cap and drain bolt for the cost of entry
Jon Petersen
25
Mar 2, 2019 08:11 PM
Moltar121
Honda CR-V & Element
Jan 5, 2019 09:47 AM
cartman
Dec 4, 2014 05:09 PM
miataguy
18
Aug 24, 2003 04:49 PM
shming123
Apr 16, 2003 11:12 AM
