Shifter linkage removal question help?
Old May 22, 2009 | 08:05 PM
mayfly's Avatar
Default Shifter linkage removal question help?
ok so im swaping my motor out. its a d16a6, im having a hard time getting the shift linkage bars off from the transmission. can any one help? its that damn 8mm spring pin or something like that. please help. want to finish this swap. thanks
Old May 22, 2009 | 08:26 PM
miguey310's Avatar
Default Re: Shifter linkage removal question help?
I just did this friday afternoon. If youre talking about the whole shifter, you're gonna wanna have at least 1 more person to help you out. Youre gonna want to take out the center console, and all of the rubber surroundings of the shifter. Then, you're gonna pull your car up onto ramps, because you will remove the shifter from underneath. When you're under the car, have your friend move the shifter so you can see the location, and you will see a bolt (13mm i believe) that holds the shifter in. You are going to unscrew this bolt, and detach the shifter from the linkage. After that bolt is out, you will notice 2 smaller bolts holding a plate that surrounds the shifter. This is where your buddy comes in handy. Have someone in the car grab the top of the bolts with pliers while you unscrew the 2 nuts (10mm) from underneath the car. THen,just pull the shifter down, and its out. Installation is just the reverse of removal, if you have any problems, shoot me a PM and ill be glad to help you out. It took me a total of 30-45 minutes working on it with my dad, only because i had to take my bumper off in order to get up on the ramps. SO good luck!
__________________
Old May 22, 2009 | 08:29 PM
matzekm's Avatar
the roll pin reqires the correct sized roll pin punch
Old May 22, 2009 | 08:41 PM
NlCK B's Avatar
he's talking about the shift linkage where it attaches to the trans i myself am taking out my linkage right now that pin is a B*t*h you got to hit the pin out with a 8mm punch
Old May 22, 2009 | 08:46 PM
Bunger's Avatar
A b***h is right... I've been calling it the "b***h pin" for longer than I can remember. 8mm punch, or if you have air, an air hammer will take it out in about .5 second.
Old May 22, 2009 | 08:49 PM
mayfly's Avatar
ok great! thanks everyone, thanks alot of help. when its day light tommorow ill try it out and let you guys know. thanks!
NlCK B's Avatar
i actually suggest replacing it with a bolt and nut just make sure you use a strong locktight
Old May 22, 2009 | 08:52 PM
89s1's Avatar
Unless the bolt needs to be hammered in due to it being such a snug fit I wouldn't do this. It usually results in seriously nasty shifter slop.
Old May 22, 2009 | 09:29 PM
Bunger's Avatar
I second this! I've lost the pin before and had to resort to a bolt for a temp fix, the shifter had about 3 times the normal travel from side to side, VERY sloppy!
Old May 23, 2009 | 04:30 AM
NlCK B's Avatar
were you guys using a bolt with a shoulder on it i used one on my other ef and i had no problems i just went threw all my miscellaneous bolts with a digital caliper and starting measure bolt until i found one that was slightly smaller than 8mm i think it was something like 7.89 or something like that the shifter had no more play then normal and i just had to give it a little love tap with a hammer to get it out i mean sure you still have to hammer it out but it's easy cuz your hitting a bolt now not a pin and punch.
skratchyy93eg
Transmission & Drivetrain
Mar 4, 2016 05:37 AM
ERKK
Mar 7, 2009 09:25 AM
sohctodohc
Oct 3, 2004 06:43 PM
Hatchdude
Jun 22, 2004 01:23 PM
araknis
Oct 25, 2002 10:30 PM
