cant shift into gear
Well I just got my motor together and running for the first time. ButI have ran into a snag. I can shift it into any gear when its turned off. But when I start the car I have to force it to get it to go into gear. Even after I get it into gear with the clutch pedal on the floor it stil wants to try to move. its like its not disengaging the clutch. I am running a stock 91 b18a1 with trans. Using a stock disk with a 95 hydro pressure plate. They are all the same. any ideas
is there enough flud in the transmission?
are you sure its a good trans?
maybe your linkage is bent or not correctly welded?
or did you get a hasport linkage?
it just sounds like a linkage issue to me try and check all your bushings and make sure everything is tight and correct.
MastaFlyMason
Transmission & Drivetrain
Sep 23, 2017 03:58 PM
