Oil Leak in the small air filter
Oil coming off the valve cover.
The little air filter. It leaks too the injectors and cause smokes.
What is the cause of this?
Help please?
Thanks in advance
b16a2 stock
turbo
tune crome
Help please?
Thanks in advance
b16a2 stock
turbo
tune crome
I started the car this morning and it smoke like crazy. the exhuast had white smoke coming out. The little air filter look dirty again.
White smoke coming from the downpipe or turbo. can't tell.
Smoke coming from your valve cover means combustion gases are entering your oil system. That typically means you toasted a piston, cracked your ringlands - something catastrophic happened in your engine.
Coupled with you blowing white smoke out of the exhaust, probably burning coolant or oil depending on the smell, it is definitely time to rip it apart.
Go ahead and perform a compression/leak down test before, but you'll only verify what most of us who have been through this before already know.
same thing happened to me four years ago only I had misfires and low compression on one cylinder. Ringlands were toasted on #1, but the other three had busted ringlands too, just not as severe.
But it may just be a busted HG, but since you are having a lot of crankcase pressure it means the combustion gasses are getting my the piston somehow.
Go for the rebuild w/ forged internals and you'll be happy.
beamer
Jul 29, 2015 03:21 PM
the.hamburglar
Sep 26, 2005 04:23 PM
PM-Performance
Feb 10, 2004 09:53 AM
bxsi
Jun 7, 2003 02:12 PM
