blow-by
Old Dec 12, 2004 | 04:42 PM
500hpsi's Avatar
Default blow-by
Do you guys get alot blow-by coming out of the breather tube? if so, what action have you done to either stop it or reduce it?
Old Dec 12, 2004 | 04:54 PM
Boosted2K's Avatar
Default Re: blow-by (500hpsi)
Catch can setup, done the right way
Old Dec 13, 2004 | 10:13 PM
PrettyLude's Avatar
check out the endyn one, its a nice piece
Old Dec 13, 2004 | 10:16 PM
CivicEJ1's Avatar
This my setup.....works get...
Before I did this there would be oil leaking from my valve cover gasket and you can tell there is pressure in the valve cover....at that time it just had a breather air filter...
Now that I did this I have not seen a drop of oil leaking from my valve cover gasket...I used clear piping so if anything but air is sucked I would know. For precaution I used a fuel filter in the middle of the line to prevent gunk & oil vapor from being sucked into my turbo...
Old Dec 14, 2004 | 02:22 AM
Boosted2K's Avatar
Default Re: blow-by (CivicEJ1)
Endyn setup over here
JDMbolo
Sep 17, 2005 04:57 PM
LSTEG96
Jun 15, 2004 09:16 PM
IloveNewt
Jan 21, 2004 10:13 PM
Sinner
Jul 17, 2003 11:56 AM
Ltech
Apr 2, 2003 01:10 PM
