B20 vtec, 86mm with nos?
Old May 19, 2009 | 07:20 PM
95dxsir2's Avatar
Default B20 vtec, 86mm with nos?
the block is sleeved @ 85mm....had alittle mishap. Now we wanna go 86mm forged rods/pistons, keeping the compression at 12:1 with a 60-70 shot. He would like to hit 300whp. cams are skunk pro 3's, intake mani will be an eldelbrock. Has anyone done this?
I know there are plenty of 86mm NA cars out there, just haven't found any info on 86mm b20 nitrous setups.
Old May 19, 2009 | 07:30 PM
CRXB18C1_ALL MOTOR's Avatar
Default Re: B20 vtec, 86mm with nos?
A friend of mine added a 50 shot wet kit on a setup similar to yours. 94 Civic Hatch street power trim ran 11.4 @ 119 mph on the motor with 248 whp. With the 50 shot nitrous, the car turned a 11.0 @ 122 mph. Yes it's possible and yes it's been done before. Good luck.
Old May 19, 2009 | 08:34 PM
95dxsir2's Avatar
thanks for the reply, and this is my buds setup. Does your friend put miles on it? track only?
Old May 20, 2009 | 03:36 AM
redflaredcrx90's Avatar
my friend did a stock b20 block and a built gsr head no nos and made 243 to the will tuned by jeff evans
Old May 20, 2009 | 05:44 AM
red02s2k's Avatar
If it's sleeved and you tune it right you can run more than a 60 shot at 86mm even at 12.1. If I was going to run that motor on the bottle I would be shooting for more of a 150 shot. Good luck
Old May 20, 2009 | 11:29 AM
95dxsir2's Avatar
he's decided on a 100 shot. Thanks guys for the info!
Old May 20, 2009 | 02:07 PM
Golden Eagle's Avatar
86 is big for nos i do not suggest it watched a friend do it and he blew the head gasket between the cylinder's and got a nice burn mark on the top of the sleeve had to pull the motor after and redeck it to fix it and regretted doing it after i told him not to
Old May 20, 2009 | 02:55 PM
CRVRX's Avatar
The issue with 86mm is indeed head gasket issues, blowing between the cylinders.
I had alot of problems with an 86mm block a few years ago, I sent it back to Golden Eagle and started from scratch again.
Old May 21, 2009 | 08:21 AM
95dxsir2's Avatar
even if both surfaces are straight?
Old May 21, 2009 | 09:48 AM
HiProfile's Avatar
Yes, because there is so little sealing surface between cylinders. Resleeving a sleeved block [to 84mm] isn't very expensive. Its probably the same price as honing to 86mm and buying custom pistons. You'll loose a very small amount of displacement, but can run extra nitrous to more than make up for it.
neverstop
Sep 13, 2022 06:23 AM
bori bori
Apr 27, 2010 02:13 PM
dirtrdr22CRX
Aug 27, 2009 07:29 PM
jdm92teg
May 17, 2005 01:07 AM
