SRS Light on & Horn not working. ClockSpring bad?
Old May 19, 2009 | 04:10 PM
hmtcrxsir's Avatar
Default SRS Light on & Horn not working. ClockSpring bad?
I bought a 95 civic ex and the car was previously stolen. They broke the ignition and so I had to replace it. So what happened was that I took everything apart to get the ignition. So I removed wiper/headlight switch, airbag, steering wheel, clockspring, etc. Just to get access to the ignition assembly. So I got that replaced and put everything back in. Horn works fine at this time. SRS light wasnt on. I might have not turn the clockspring pointed in an up direction prior to replacing the steering wheel. So when I might a U turn, I heard like click sounds like something wasnt right. So I parked, and the SRS light came on. Then I tried pressing the horn button and nothing! Wasnt working. So Im not sure if i messed up the clockspring behind the steering wheel. Any suggestions what the problem may be? The SRS reel looks fine to me.
Old May 19, 2009 | 04:16 PM
hmtcrxsir's Avatar
Default Re: SRS Light on & Horn not working. ClockSpring bad?
I think I may have figured it out. I didnt place the steering wheel back on Dead Top Center and when I made that U Turn. I snapped the Clockspring/Reel
Old May 11, 2010 | 06:29 PM
Markb16a's Avatar
what is the clock spring? I would like to know because I cant figure out why my horn isnt working I have tryied everything.
Old May 11, 2010 | 07:15 PM
BluE-EK's Avatar
yep is that, when i brought my hatch 98 have the same problem,
and i open the ... "that think"... and present some damaged flat wires and cut the area damaged and re-solder the wires and!!! taaa...daaaa... no more problems...
Old May 11, 2010 | 07:20 PM
Kuhniee's Avatar
dido on what is the clock spring?
Old May 11, 2010 | 07:51 PM
BluE-EK's Avatar
im talking about number 2 think!
Old May 12, 2010 | 06:22 AM
Wish2345's Avatar
had the same issue with a 97 accord and it was the clock spring issue
Old May 12, 2010 | 08:13 AM
fungus mungus's Avatar
Also known as a 'cable reel', it's the mechanism that manages your wiring to your horn and your airbag. If it's installed improperly, the wiring, which is quite fragile, will break and you'll loose functionality of your horn and airbag (thus the SRS light coming on). I've done this as well. You have to be really careful when taking this part on and off the steering column...it's deceptively easy to break...only 3 screws hold it on, so it seems like it's easy to take on and off, but if you manhandle it, or if you install it wrong, you'll be looking for another one at the junk yard. Or buying a new one from Honda for $250.
fm
Old May 12, 2010 | 08:19 AM
Deetz's Avatar
Crazy Honda Guy
The clock spring or cable reel can be damaged easily because it can only be turned in either direction by only 2 rotations, any more than that will wreck it!!!!!
When ever i remove one, i put a zip tie over in a center position right away just so not to mess it up. This is why dealerships have tech's that know stuff like this that the average public does not
Old May 12, 2010 | 07:22 PM
Kuhniee's Avatar
so my 95 eg s horn doesnt work and the fuse is good... horns plugged in but could it be this even tho my SRS light isnt on? or cound the actual horn just be junk?
jr408
Mar 6, 2008 01:28 PM
erck
Jun 8, 2007 07:34 PM
92ehatch
Jul 30, 2006 05:57 PM
Marauder
Apr 11, 2003 03:26 PM
AmginE
Nov 13, 2002 08:04 PM
