Throttle/idle problem
Old May 19, 2009 | 04:05 PM
SIBlue00's Avatar
Default Throttle/idle problem
i have a 2000 civic si with a built ls vtec jumped to obd1 with a p28 ecu when i drive it the throttle will cut out at like 3 grand and then come back and throw me back into my seat like whiplash and i hate it so does my gf haha and its in every gear i can sit at idle and press teh gas slightly and itll rev to 3 grand and drop back down and go up and down and up and down....i replaced the throttle cable for fun and i was told to calibrate my tps sensor help me!
Old May 19, 2009 | 04:14 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Throttle/idle problem
Sounds like limp mode.
CEL?
Old May 19, 2009 | 04:17 PM
tuhboek's Avatar
Maybe an IAC valve problem?
Old May 19, 2009 | 09:51 PM
Decaf's Avatar
bump, i have the same issue
Old May 20, 2009 | 08:28 AM
SIBlue00's Avatar
iac valve is fine...check engine light is tps angle code 7 i beleive its just so annoying anytime i pull out it drops then it comes back in and i peel out it sucks
Old Oct 6, 2009 | 09:20 PM
CHR's Avatar
CHR
TRIAL USER
Am having a similar problem with 2000 Civic. Only mine idles high. I replaced IACV and TPS. What did you do to fix this?
Old Oct 7, 2009 | 07:36 AM
R666_EK's Avatar
Uh. I'm willing to bet that's your problem right there...
Old Oct 7, 2009 | 08:06 AM
darrinbrewer's Avatar
i would check the calibration on teh TPS, it should be somewhere close to center, if its rotated 1 way, loosen the screws and bring it back to center.
Old Oct 22, 2009 | 06:03 PM
hondarules7's Avatar
Sounds like its time to replace the TPS. They develop "dead spots" in the throttle range from idle to WOT and that will cause the problem you are having, and ironically your CEL is on giving you a TPS code.
Old Oct 22, 2009 | 07:09 PM
CHR's Avatar
CHR
TRIAL USER
Thank you for the feedback. I will try repositioning the TPS (which is new) and let you know what happens.
Old Oct 22, 2009 | 07:11 PM
R666_EK's Avatar
Don't just eyeball it. It should be calibrated with a Multimeter.
Snakecharmer
Honda S2000
Oct 9, 2018 02:06 PM
Blazin Civic
Apr 13, 2005 01:41 PM
PowderB16
Jan 8, 2005 09:27 PM
B16CRXT
May 25, 2004 07:46 AM
