headlights with running lights question
looking through some pics in the ej8 thread and was wondering about the headlight glow. some lights are on inside the main bulb area but theres no way that the actual head light is on? are there aftermarket housings with a little running light bulb? thanks in advance
I believe you are referring to JDM city lights. They are easily installed with the correct headlight housing, otherwise it takes some fabrication. If you are interested in city lights, do yourself a favor and buy the correct headlights. Also, for a true JDM look, don't forget to set up your corners with the same city light treatment.
JDM, UKDM, Canada?, whatever other markets there are.
there talking about CTR lights with the city light built in.
you can buy a city light socket and add it in to your stock light if you want.
ctr lights can be bought new for anywhere bewteen 400-500
here are the "correct" lights CountDracura was taling about
http://hmotorsonline.com/shop/sc2000...age&item=10004
here are the sockets ( not sure if hmotors includes them)
http://inlinefour.com/honcitligsoc.html
and all you would have to do is wire them in with the parking light or buy the harness
i was just letting the OP know that he doesn't have to buy CTR headlamps for 4bills to have city lights. even though if it were me, i would buy them.
I meant that in Japan, when city lights are utilized, the small bulb on the inside of the headlamp and the side markers are lit. I apologize, when I said "corners" I meant to say "side markers", my bad. It does add a unique JDM look in the end.
actually, i believe sidemarkers are only lit when signaling. *thumbsup*
