GSR Turbo Project ???'s
Old May 15, 2009 | 07:24 PM
gsrauto98's Avatar
Default GSR Turbo Project ???'s
So I am currently starting my build for boost, and I have a few questions/opinions needed about a few things. First off i have read a few different things about headgaskets, I was wondering if i should go with a thicker headgasket and what thickness, but i have heard people having problems when they use a thicker head gaskets and oem might be the best. Also I plan on changing pistons to around a 9.0-1 compression piston but with the stock bore size, what are the best bang for your buck pistons for boost apps out there and rods. And i was thinking of either getting a block guard or getting it sleeved, im not sure which one would be the most pratical for my application. And for cams I have seen great results with blox b's and skunk2 pro 1's but blox cams are quite a bit cheaper and not sure if the skunk2's are worth it, the valve train will be upgraded with supertech springs and retainers. I am looking to run around 15 psi and it still be a daily driver.
And hopefully on a good tune with 450whp. All help is appreciated and if anyone has any suggestions or anything please dont hesitate to say whatever it is.
Old May 16, 2009 | 09:13 AM
thewrai6th's Avatar
Default Re: GSR Turbo Project ???'s
The valve train will be upgraded with supertech springs and retainers
1 should go with a thicker headgasket and what thickness
2 what are the best bang for your buck pistons for boost apps out there and rods.
3 i was thinking of either getting a block guard or getting it sleeved,
4 blox cams are quite a bit cheaper and not sure if the skunk2's are worth it
I summarized the questions
1 Most people run OEM, thicker is not needed.
2 There are alot of options, just look around in the site classifieds.
3 Probaby overkill
4 Have not used either one.
Old May 16, 2009 | 09:28 AM
gsrauto98's Avatar
^^^thanks, and 39 views with only one response
Old May 16, 2009 | 11:19 AM
gsrauto98's Avatar
bump
Old May 16, 2009 | 12:48 PM
TheShodan's Avatar
Moderator
Sometimes only one response is needed. He made it pretty clear..
Good luck.. get to work.
Old May 16, 2009 | 03:20 PM
Ricer no 7's Avatar
I'm not a pro but in the process of building a 450 whp build.
OEM head gasket
EAGLE RODS are cheap and fine for your goals(or just shotpeened stock rods) also most forged pistons are nice just find a deal on a reputable brand. wiesco, arias, etc
SLEEVED if you want the extra safety (if not don't use the either block guard or sleeved just go with pistons and a good tune.) Plenty of people have made power with stock sleeves.
For 450 whp all you really need is gsr cams or type r if you want you can save the money there
Look for deals in here on honda-tech
got my block from someone selling it on HT here for $1500 with
RS sleeved 83 mm ls block
crower rods
arias pistons
acl race bearing
micro polished ls crank
fully assembled.
An my b16 head with supertech valve train for like 450
look around the classifieds you will be surprised what you can find. Now just saving for the turbo set up and be ready to go
subman20
Oct 9, 2013 07:55 PM
95dc2teg
13
Dec 17, 2009 04:21 PM
spgcuantik
Nov 28, 2007 08:17 AM
ping83
Jul 17, 2005 12:30 PM
oMek
Feb 2, 2004 09:25 PM
