Bleeding clutch fluid
So I found a loose fitting and decided to bleed the system out 3 times due to the fact that I have slack in my pedal. I still have slack in my pedal. WHAT MORE MUST I DO TO RID ME OF THIS PROBLEM?
The master is fine. The master took a **** a month ago. This is what happened: Both of my tranny mounts busted and the bolts were sheared off inside of the case, so I had to have it machined and have the threads re-tapped. Im thinking that they either installed the slave incorrectly or the slave took a ****. I have been having this particular problem since I got the car back, but I noticed that the pedal would randomly lose pressure. I bled it and then a week later (a few days ago) the pedal practically took a **** on me. I popped the hood and saw A TON of fluid had just leaked out in my driveway when I got home. I noticed that the fitting closest to the bleeder valve was loose, so I tightened it up and bled the system again. The pedal is stiff now, but it still has slack. Im talking about a little over 1/4 of the motion of the pedal is completely loose. How do I go about adjusting the pedal?
Duck Sauce
Apr 13, 2008 09:30 PM
