Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
clutch bleeding issues
Old Aug 21, 2008 | 06:47 PM
autoxthis's Avatar
Default clutch bleeding issues
i have replaced my cmc, slave, and hard lines. I am in the process of bleeding the system but I have a huge problem. No, and i mean no fluid is being pumped by the cmc (clutch master cylinder). I feel no air pushed through the bleeder nipple and the fluid level in the resivoir is certainly not decreasing when I try to 2 man bleed the system or one man for that matter.
I think I bench bled my cmc but its my first time doing it and the instructions were for a brake master cylinder not a cmc.
This is the second cmc i've tried so ITS NOT the cmc or the slave. No holes in the hard lines, and no leaks anywhere!
I'm dumbfounded with the crap and I'm considering hari kari, so please help!!!
Old Aug 21, 2008 | 06:58 PM
B16B_coupe's Avatar
HRD PKR
Default Re: clutch bleeding issues (autoxthis)
is it leaking at all on the inside of the car?
Also when you bleed it,
1:loosen the 8mm or 10mm on the slave
2:then push the pedal to the floor.( not all the way to the floor or it will damage the cmc)
3. then tighten the bleed screw
4: then hand pump (eventually when it builds up pressure it will come back on its own.
5: re-peat
Old Aug 21, 2008 | 07:05 PM
autoxthis's Avatar
Default Re: clutch bleeding issues (B16B_coupe)
no leaks. I'll give this a try.
Any other ideas?
Old Aug 21, 2008 | 07:09 PM
smokin rubber's Avatar
try the gravity bleed, just open up the bleeder on the slave and keep the reservoir full.
Old Aug 21, 2008 | 07:23 PM
autoxthis's Avatar
Default Re: (smokin rubber)
done that but no bones. in fact no fluid. this made me think there is a crimped hoses or **** stuck in the lines, yet i checked and it all seems clear.
Old Aug 21, 2008 | 07:38 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (autoxthis)
try my method might take a few trys just give it a shot, you replaced everything! That mean's no pressure at all in the system.
Old Aug 21, 2008 | 08:23 PM
autoxthis's Avatar
Default Re: (B16B_coupe)
got it finally, thanks!
autoxthis
Aug 25, 2008 05:45 AM
autoxthis
Honda Civic (2006 - 2015)
Aug 24, 2008 05:46 PM
autoxthis
Aug 21, 2008 11:19 PM
autoxthis
Aug 21, 2008 08:56 PM
