My DSM CatchCan Setup
Old May 10, 2009 | 01:44 PM
HamiltonRex's Avatar
Default My DSM CatchCan Setup
Everyone knows DSM's suck for crankcase venting from factory... and lots suffer from blowing out the dipstick and making a oil mess and possible fire hazard. Here is my solution..
I removed the baffling from the Valvecover, used two -10 fittings, the can is a fair size.. and than it has to two vents on the top. I also use a -8 drainback to the pan.
I also mounted my battery it so its out of the way, it fits nicely and I can still get to it no problem to boost it if i ever have too. Plus no disconnect needed since its still under the hood.
Old May 10, 2009 | 01:47 PM
JDM KID 510's Avatar
Default Re: My DSM CatchCan Setup
Nice work.
Old May 10, 2009 | 01:52 PM
vietjdmboi's Avatar
what kind of hose ends are you using?
Old May 10, 2009 | 01:58 PM
the hoses and fittings are all just push-loc A1 Performance stuff, and the weld on fittings are vibrant, same stuff I used for all my fuel lines.
Old May 10, 2009 | 02:35 PM
89civicdx's Avatar
cool did u make the can too
Old May 10, 2009 | 03:59 PM
yea I designed the can and cut/fit the pieces. I had weirtech just strictly do the welding. I'm happy with the way it turned out
Old May 11, 2009 | 01:13 PM
QuangAlang's Avatar
where did you get the hoses?
Old May 11, 2009 | 03:59 PM
speeddave's Avatar
looks good! how much did those vibrant weld on fittings cost you?
Old May 11, 2009 | 04:27 PM
Nick Z32's Avatar
is your talon stroked?
Old May 12, 2009 | 08:18 AM
no, talon is stock 4g63 crank 2.0l. Hoses/fittings I got from extremepsi.com
Thanks
Old May 12, 2009 | 08:28 AM
fastcody1's Avatar
Nice setup.
did wraping you charge piping help much with you intake air temps?
Old May 12, 2009 | 12:08 PM
Originally Posted by fastcody1
Nice setup.
I honestly doubt it, I run a 25/75 mix of chilled water/meth when im at power levels and/or have ambient temperatures im concerned with. My IAT's are always fair close to ambient.
5thgen
Jun 9, 2011 08:11 AM
boredracer408
Jul 26, 2004 03:28 PM
queez
Mar 31, 2003 03:01 PM
pelotudo
Aug 24, 2002 12:20 AM
