Integra Smoking??
i got a 91 DA with a b18a1 th car has moisture coming out the exhaust i need some help on figuring it out i did compression check all cylinders were 165 or higher other than than all i have on the car is a aem cai and an hks highpower exhaust
Some people try seafoaming their cars...It's made to clean carbon, and varinsh build up off the valves, pistons, rings, etc. Will also help clean sticky lifters or valves...you could try that...maybe some fuel cleaner
dont use seafoam, especially if it is a old motor. sea foam just unclogs your rings of oil deposits and will smoke more eventually. could be possible head gasket leak that is very small.
if its a small head leak compression should leak too i know about seafoam and yes u are right about the old motors this is just a weird situation what else could cause it?
Ok well...Whitish smoke is usually caused by water or antifreeze entering the cylinder, and the engine trying to burn it with the fuel. The white smoke is steam. There are special gaskets (head gaskets are the primary gaskets) that keep the antifreeze from entering the cylinder area. The cylinder is where the fuel and air mixture are being compressed and burned. Any amount of antifreeze that enters this area will produce a white steam that will be present at the tailpipe area. If white smoke is present, check to see if the proper amount of antifreeze is inside the radiator and the overflow bottle. Also check to see if antifreeze has contaminated the engine oil. You can look at the engine oil dipstick, or look at the under side of the engine oil filler cap. If the oil is contaminated with antifreeze, it will have the appearance of a chocolate milkshake. Do not start the engine if the oil is contaminated with antifreeze, as serious internal engine damage can result...you said it was light smoke right? like a whitish color?
also, i found out on my DA when my headgasket started too go, i seen a mixture of oil IN my radiator fluid about week before my actual oil got milky. check your oil cap and if its a milky white color, you'll know. then check your radiator to see if any oil is mixed in the fulid.
i already checked it and there is none at all thats why im confused i check all my oil and oil cap there is no mixture i would have known if there was a ,mixture but there isnt so im still wondering what else could it be
some times even tho you let it idle for two hours the exhaust still may not be warmed up enough. take a 15 min ride and see if it still smokes. had the same problem just needed heating up. more gases more heat no condensation.
nengx07
Jun 1, 2010 08:50 AM
RedCd5TX
May 10, 2008 06:14 AM
