LS Into 2000 Civic EX
Old May 6, 2009 | 04:48 PM
TravisCadello's Avatar
Default LS Into 2000 Civic EX
Ok, My homeboy let me test drive his 94 integra Ls Today and it ran good but its slower than a single cam. but whats new? anyways hes selling my friend the motor/tranny,ecu, complete wire harness,spindles complete,axles. Pretty much EVERYTHING that a car needs to run and drive for 700 bux. Well my friend has a 2000 EX and wants to know if everything is gonna be compatible and what will he and i need to do to make this possible?
And if it makes a difference it is a automatic tranny.
Thanks!
Old May 6, 2009 | 05:03 PM
98civdx's Avatar
Master Detailer
Default Re: LS Into 2000 Civic EX
ok, the ls is a auto or the car is?
is car is he will need to swap it to 5spd. or if the motor is just get a b16 or gsr tranny.
Old May 6, 2009 | 05:20 PM
The LS Has a Auto Mated to it. My friends EX Is 5spd but was auto at one time, so we can easily swap it back to automatic. i just need to know what needs to be done to the wire harness for it to work and run. and what all do we need to do to make this happen?
Old May 6, 2009 | 05:35 PM
Bump?
Old May 6, 2009 | 06:04 PM
Can we move this thread to somewhere that people help?
Old May 6, 2009 | 06:13 PM
94EG8's Avatar
Seagull Management
Automatic B-series swap in a '96 - '00 pretty much just isn't going to happen. Even on an automatic civic it doesn't work for a few reasons:
1. You have to cut and notch the frame rail to make the much larger B-series automatic tranny fit.
2. You have to fabricate your own mounts because non exist
3. due to differences in how the civic and integra transmissions are controlled its extremely difficult to get the transmission to shift properly. (you have to wire in an Integra TCM)
Pick up an LS 5 speed tranny.
Old May 6, 2009 | 07:02 PM
Ok, so if he buys everything except the tranny and buys a 5spd it will all work?
Old May 6, 2009 | 07:14 PM
94EG8's Avatar
Seagull Management
You will need:
-5 speed B-series tranny
-rear T-bracket and timing belt post mount from a '99 - '00 Civic Si (nothing else works)
-5 speed OBD2B LS ECU with the immobilizer removed, or an OBD1 or OBD2A LS ECU with a conversion harness
Old May 8, 2009 | 09:44 AM
fc3srx729's Avatar
if it was auto, he's gonna need a tranny, shift linkage, shifter, mounts, and axles...
waynecoSI
Jul 4, 2008 08:59 AM
[Ennis_D]
Nov 18, 2005 05:33 AM
99SlammedCivic
Mar 24, 2004 10:44 AM
4g4me
Mar 26, 2003 10:30 PM
