sohc problems motor won't start
My motor doesn't get any spark . engine turns over just doesn't start . I have replaced distributor, replace main assembly relay, fuses, and reset ecu. Please HELP!!
Do you have battery voltage on the BLK/YEL wire attached to the igniter unit in the distributor when the key is turned to ON(II)?
Do you have an open or short in the YEL/GRN wire that attaches to the igniter unit and runs to the ECU?
What kind of wires are they? I recommend only OEM Sumotomo or NGK. Cheap no-name parts store wires are known to pull apart internally. I've had a number of sets fall apart on me straight out of the box.
well man if you have spark at the destributor but not at the end of the wires when plugged in...
there is a short in the wires
replace them... start your car
clean95hatch
Dec 13, 2012 09:13 AM
ejprimo
Apr 25, 2003 10:20 AM
