ITR vs CTR JDM exaust specs
Old May 1, 2009 | 07:00 PM
egotistic's Avatar
Default ITR vs CTR JDM exaust specs
i have a 97 jdm b18c.... and a 96-00 CTR exhaust system....not sure what year lol
question is will the itr header fit the ctr exhaust.... are the diameters the same
96 spec itr header diameter____?
98 spec itr header diameter is 2.5" i think
ctr header and exhaust diameter ____?
if anyone knows the diameters please fill in the blanks
Old May 1, 2009 | 07:51 PM
shwanC's Avatar
Default Re: ITR vs CTR JDM exaust specs
I have the complete factory CTR exhaust on my 92 hatch (fit right up) and the diameter is around 2.25"...in fact, bolted straight up to B16A factory header. I would think the ITR header is larger than CTR, but I wouldn't expect much dif. Running ITR header on there would be nice, if one could be found cheap. But an aftermarket would be a better choice.
But yes, it will fit.
Old May 1, 2009 | 07:59 PM
egotistic's Avatar
so the CTR exhaust is 2.25"..... so the last question is..... whats 96spec itr header diameter.... 2.25 or 2.5?..
Old May 1, 2009 | 08:07 PM
Got traction's Avatar
just have a test pipe made that goes from 2.5 to 2.25 so you can run the ctr exhaust.
Old May 1, 2009 | 08:43 PM
egotistic's Avatar
thats what i was thinking id have to do.... whats the power difference from going down diameters like that? anyone have any idea.... a 1/4 inch a big difference? little more back pressure?
Old May 1, 2009 | 08:46 PM
if you were turbo like the red coupe at your work it would be...hahaha you should be fine going 2.5 to 2.25
Old May 1, 2009 | 09:16 PM
egotistic's Avatar
haha we got jokes.... so any definite answer on the 96spec header diameter? 2.25 or 2.5?
Old May 2, 2009 | 09:25 AM
jungletronic's Avatar
JDM EK9 CTR and DC ITR exhaust manifold outlets and cat inlets should match up @ around 2-1/2". My 98 spec ITR exhaust manifold bolts up; I think the 96-97's have the same size outlet although they are different manifolds.
itgrowsind
Sep 5, 2008 09:05 PM
TypeR 599
Oct 6, 2005 03:20 PM
marc-111
Aug 15, 2005 08:01 AM
Speedz
Mar 31, 2003 05:20 AM
