190F too hot??
Old May 1, 2009 | 03:14 PM
boostedb20z's Avatar
Default 190F too hot??
is the temp to hot ??? and its goes from 186 to 190 stays around there but is that to hot could it damage things??
Old May 1, 2009 | 03:49 PM
Ls_dx's Avatar
Default Re: 190F too hot??
No your fine. it does sound warm but not what I would consider "danger zone"
Old May 1, 2009 | 06:53 PM
non-VTEC's Avatar
190f is fine.
anything under 205f is perfectly fine and safe....
Old May 1, 2009 | 08:38 PM
well this was just sitting ideling nothing more ill see where it is tommrow driving down the road but thanks for all the help
Old May 2, 2009 | 03:58 AM
champwhiteEG6's Avatar
That's normal operating temperature. Thermostat fully opens around 194f
Old May 2, 2009 | 05:26 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
exactly. Some wish they had that.
Old May 2, 2009 | 01:58 PM
well i took it for a drive today and it got hot 229f and i shut it off anyone running a 750 intercooler having cooling problems??
Old May 2, 2009 | 02:22 PM
intense4thgen's Avatar
fan running the right way? i made that mistake once
Old May 2, 2009 | 03:31 PM
fcm's Avatar
fcm
Old Fart
Is rad fan turning on at or about 190degrees F?, if not it should be.
As mentioned, make sure read fan is turning in the right direction, pulling air through the rad.
How much of the rad is covered by the inter-cooler?
Is it clean between the inter-cooler and the rad?
Hint, never shut off an overheating engine, pull over and let idle till it cools down, if temp. still increases when idling then shut the engine off.94
Ej1SIR
Apr 14, 2010 05:02 AM
felixjr18
May 5, 2009 11:30 AM
EFOwNzALL
Jun 24, 2008 09:09 AM
Hybrid
Feb 13, 2002 02:45 PM
paulzy
Aug 21, 2001 02:37 PM
