Hyper Blink.... -_-, how to fix?
Old Apr 30, 2009 | 10:58 AM
DC206R's Avatar
Default Hyper Blink.... -_-, how to fix?
after i got my swap in, everything is running but my turn signals HYPER blink and its annoying. What are things that could cause this?
i checked the fuse for the front turn signals and its fine.i dont have any other ideas. Could a broken bulb cause this?
i have a 95 LS BTW.
Old Apr 30, 2009 | 11:04 AM
dmotoguy's Avatar
Default Re: Hyper Blink.... -_-, how to fix?
bulb or a short somewhere.
Old Apr 30, 2009 | 11:15 AM
seanbev24's Avatar
x2
Check all the bulbs, if they're good you probably have a short
Old Apr 30, 2009 | 11:56 AM
TunerN00b's Avatar
As stated, sounds like a blown bulb.
Or you have LEDs in one of the turn signals. Without a resistor, LEDs will cause the hyper blinking.
Old Apr 30, 2009 | 10:16 PM
DC206R's Avatar
ok, i'll check and if needed, replace the bulbs too. But if i have a short, where do i start to look?
Old Oct 10, 2012 | 10:05 AM
guyver13's Avatar
reviving an old thread because I have the same problem, all bulbs in tact
Old Oct 10, 2012 | 05:01 PM
ltrkstr2k's Avatar
my accord did the same thing. all bulbs were fine. changed the flasher and problem fixed
Old Oct 13, 2012 | 06:34 AM
Fnix's Avatar
what is the flasher cause I am having the same prob
Old Oct 13, 2012 | 07:50 AM
fcm's Avatar
fcm
Old Fart
It is the signal/hazard light relay. 94
Bambooseven
Mar 3, 2009 08:40 PM
B20inDCinLBC
Jul 5, 2006 04:56 PM
jdm_junkie
Aug 12, 2004 06:09 PM
GSblueRacing
May 28, 2004 06:27 PM
B16ED4G
Feb 27, 2002 07:43 AM
