PLEASE HELP ME!!! Distributor was making noise and now trans fluid is leaking near it
Old Apr 29, 2009 | 09:42 PM
EChangApe's Avatar
New User
Default PLEASE HELP ME!!! Distributor was making noise and now trans fluid is leaking near it
I dont know what to do, but the tranny fluid is for sure leaking from/through the distributor by it. its red fluid someone told me its the tranny fluid. some friends told me its the gasket. but i dont know. should i get a new distributor and then get a new gasket? and i have no idea how to time the distributor! some one help me please on anything i can do to fix. the distributor was making lots of noise for a while and then it quieted down and then it leaked. i think its because the gear was grinding against something and that made a whole. please, i love my car, and i dont want to give it up, and dont have money for the overpriced tranny shops here.
THank you for looking and helping.
Old Apr 29, 2009 | 09:48 PM
Former User's Avatar
Default Re: PLEASE HELP ME!!! Distributor was making noise and now trans fluid is leaking nea
It's more likely motor oil than transmission oil. Remove the distributor connector and the three bolts. The distributor should then just slip out. Inspecting the inside of the removed distributor should reveal the problem. Replace the O-ring on the shaft to stop the oil leak.
Old Apr 29, 2009 | 10:06 PM
RunninEg6's Avatar
^^^very simple. 3 12mm bolts to unbolt. the o-ring is most likely your problem and a new one is less than $5. dont worry
Old Apr 29, 2009 | 10:09 PM
Unseen Racer's Avatar
bulls eye!
you dont even have to worry about timing.
just remove, replace o-ring and re-install.
Old Apr 29, 2009 | 10:21 PM
XKINGX's Avatar
use something to to mark your dizzy location. like white out. just make a line acroos the top ear of the dizzy to the cam cap on the engine.
Old Apr 29, 2009 | 11:22 PM
EChangApe's Avatar
New User
Thank you guys!!! I will definitely check the ORing THIng. I am hoping thats the only prob. THank you~!~!
Old Apr 29, 2009 | 11:46 PM
anothersickhatch's Avatar
how is it possible that a) transmission fluid would be leaking out of a part that is impossible for tranny fluid to leak from?, and b) is it manual? manual transmission fluid is yellow/amber color. not red. it would have to be an automatic.
Old Apr 30, 2009 | 11:16 PM
EChangApe's Avatar
New User
okay you are right. its motor oil. for b) my car is an automatic.
umm...lets see. i dont know where the o-ring goes, but gasket missing so our roomate replaced it with part of a bottle nip. hmm. im going to buy the oring, but where does it get placed?
Old May 1, 2009 | 12:11 AM
1992Si's Avatar
If the dizzy is making noise, it's most likely the bearing inside it. Replace the dizzy with a rebuilt one from a auto parts store.
When you pull the dizzy out, you will see the o-ring.
It can be a pain to disconnect the two plugs on the dizzy, you need to press one clip in and lift the clip at the same time.
I think the rebuilt dizzy comes with a o-ring.
Old May 1, 2009 | 02:54 AM
Don't buy a re manufactured distributor from an auto parts store. they aren't reliable and are made of low quality parts. at the very least buy a used, low mileage one.
ribal_gh
Nov 10, 2012 10:00 AM
blacktibby07
11
Feb 5, 2011 03:12 PM
blackmfoggie
Aug 23, 2007 12:09 PM
sickvtec
May 21, 2004 05:41 PM
jcda6
Sep 30, 2003 09:46 PM
