climate control problem!!!
okay my climate control light all works, but air doesnt blow out when i turn it on, and my rear window defrosters don't work. i've taken off my climate control to check the wirings and they seem fine, i really don't know what else to do, its been raining all week and i can't see when i drive cause i have no defrosters front and back!!! lol, and i keep blowing a fuse for my passenger side window whenever i put a new fuse in, i know theres a short but damn i cant find that wire short anywhere!! no ac, and windows not working in texas weather is killer!!
The rear window defrost is controlled by the ICU.
For the front the first thing I would check is the blower motor, test the blue/white lead at the blower motor two pin plug, it should test as 12V+ when ign. switch is in the run position.
If there is 12V+ at the blue/white lead, [with ign. on] use a jumper wire to supply a direct ground to the blue/black lead, stuff one end of jumper into plug with blue/black lead/terminal and touch the other end of jumper to any chassis ground point, does blower motor work? 94
They are LEDs and it is unlikely they are all blown, check fuse 17 - 7.5A, [hot in run] in under dash fuse box.
Do any of the indicator lights, [or illumination lights] work in the climate control head?
Did you try what I suggested with the blower motor?
If so, what did you find? 94
woody7121
May 12, 2015 04:03 PM
mormonboy
Sep 7, 2007 10:24 PM
