Steel Catch can?
I dont have access to a Aluminum welder, but I do have one for steel. Would I be ok to use steel as opposed to aluminum? This is not going to be drain back. Its going to be open vented.
sure u can, as long as the contaminated oil doesnt make its way back into the motor .. oil will seal it up but IT WILL eventualy RUST due to the condensation.. try it and let us know how you make out!!!
I have done a mild steel catch can out of sheet and a coolant reservoir out of tubing. Two years, no rust issues. Even cracked them open to check. It was more of an experiment than anything, but it worked out well.
GruvyTune
Jan 24, 2002 08:35 AM
