New suspensions, new bushings?
Old Apr 27, 2009 | 11:25 PM
SlowEJ8's Avatar
Default New suspensions, new bushings?
Okay, i'm helping one of my buddies post.
He lowered his cars with new shocks and springs, but soon after he lowered it.
I'ma ssuming a couple of days/weeks his car started to squeek bad.
It's the same car as mine, Civic 2000.
Question is: Could there be ANY way that it'll use up your lca bushings more with aftermarket parts? thanks
Old Apr 28, 2009 | 11:54 PM
SlowEJ8's Avatar
Default Re: New suspensions, new bushings?
bump
Old Apr 29, 2009 | 06:20 AM
jdmztrane's Avatar
More than likely the bushings he had are original.... and seeing as how the car is at least 10 years old, they are probably worn out. You can't "use up" bushings, but they do eventually go bad and need to be replaced. That's probably why you have the squeaking. Best bet is to replace them, or man up and deal with it until you do.
Old Apr 29, 2009 | 06:28 AM
joelmatt89's Avatar
BTW if you do end up replacing the bushings there is a really easy way to get them out without using a press. When I did mine all the shops said they wanted 100 to press them. I just used a hole saw to get the inner metal sleeve out along with most the rubber. Then just use a sawz all to cut the outer sleeve in two spots then just hit the sleeve with a hammer and screw driver and it will slide right out. It worked out really good for me and was quick. The worst part was all pieces of rubber covering my garage
Old Apr 29, 2009 | 08:11 AM
Duc_du's Avatar
i got similar problem. so how much does it cost to get them bushing replace anyway? since im not experience with car at all.
Old Apr 29, 2009 | 08:37 AM
chinese acrobat's Avatar
My bud's integra was squeking too, he got a energy suspesion kit and replaced the front end bushings and the squeking stopped.
If he was to do it all over again he would just swap the front LCA bushings...but for the price, might aswell get the whole kit.
Old Apr 29, 2009 | 02:45 PM
SlowEJ8's Avatar
But the for my friends problem, it seemed that it only went bad after he got the suspension setup, anyone know why or is it just coincidence? thanks.
Old Apr 29, 2009 | 02:52 PM
MonkeyMagic's Avatar
because the rubber bushings got used to being attached at a certain angle, now with it lower they are tweaked in angles they aren't used to. so every bump they complain
Old Apr 29, 2009 | 03:18 PM
jdmztrane's Avatar
That would only happen if you didn't pre-load the suspension before tightening the bolts all the way. If you pre-load the suspension, the bushings wont be twisted, and wont wear out as fast.
Old Apr 29, 2009 | 04:17 PM
IhateworkingoncaRs's Avatar
So you got them out and the shop pressed them in? Cuz if you got a trick to getting them in I want to know LOL. $100 just to press them in is alot.
Old Apr 29, 2009 | 04:30 PM
civic_driver's Avatar
When I did my own bushings, I pressed them in myself. I used aftermarket polyurethane bushings which came with the grease so maybe that's why they slided in so easy (actually, I did it a while back, can't remember how easy it was really). It was time consuming especially getting the old ones out because you have to cut them but getting the new ones in was easier, IIRC.
Also, if you put a stiffer suspension in there, it will destroy the bushings even more and maybe cause that squeak you're hearing.
DJKellogg
11
Apr 1, 2014 10:47 AM
Ur 2 Slow 4 J
Suspension & Brakes
Mar 9, 2011 12:14 PM
Eran
Suspension & Brakes
Feb 15, 2007 05:10 PM
aserenehope
Dec 7, 2006 02:27 PM
LSEGHATCH
Aug 25, 2005 07:19 PM
