Civic EX Alarm Install...Where to pin lock/unlock wires?
I am about to install an alarm system in my EJ and was wondering if there is any other way to tap into the lock unlock wires without going to the door? I have looked at wiring diagrams and they say that there are wires in the drivers kick panel that you could tap to while others say that you have to get to them at the door.
For those of you with alarms in EX, can you please let me know if there is a way to tap the lock/unlock wires inside the car without having to run wires to the door?
Thanks....
Thanks....
where the door harness comes into the car.. i think it is a blue plug or you can get it at a green plug behind the radio... this is for a 96-98 civic
Door Lock Green/White (-)
Door Unlock Green/Orange (-)
also at the green plug
Door Trigger Light Green/Red (-)
Trunk Pin Blue/Black (-)
Horn Wire Gray (-)
Horn Wire Gray (-)
Horn Wire Gray (-)
Horn Wire Gray (-)
Should have said it was a 92-95 to begin with, makes it a lot easier. This will also probably get moved to the Audio/Security forum.
Door Unlock Green/Red (-)
Trunk Pin Green/Black (-)
Horn Wire Blue (-)
Horn Wire Blue (-)
Oh, and I just noticed you posted this question in the Audio/Security forum as well; and again you didn't give the MMY. Always list the make, model, and year; it really helps answering the questions.
I know the color of the wires but I need to know if there is a place to tap into the wires inside the car instead of in the door so that I don't have to run wires to the door.
Thanks for all the help!!!
At the driver's running board
Above fuse panel blue connector
Steering column
Horn Wire Blue (-)
I highly recommend checking out this killer website. This guy has spent a lot of time detailing some really important car security information.
http://causeforalarm.thecarthing.com...on7/index.html
Thanks for the help mechanix619
I don't have a picture but the wires are right behind the drivers kick.
I was taking a look at this thread....
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-95-civic-power-door-conversion-right-way-tons-pics-end-all-swap-2337026/
an saw this picture...
Is the small grey plug where you can connect the lock/unlock wires to?
ussop
Audio / Security / Video
Mar 13, 2015 11:36 PM
JaySauce
Apr 18, 2009 05:11 PM
slow motion
Aug 17, 2004 12:57 AM
