Civic EX Alarm Install...Where to pin lock/unlock wires?
I am about to install an alarm system in my EJ and was wondering if there is any other way to tap into the lock unlock wires without going to the door? I have looked at wiring diagrams and they say that there are wires in the drivers kick panel that you could tap to while others say that you have to get to them at the door.
For those of you with alarms in EX, can you please let me know if there is a way to tap the lock/unlock wires inside the car without having to run wires to the door?
Thanks....
Thanks....
Re: Civic EX Alarm Install...Where to pin lock/unlock wires?
At a 2 pin connector taped to blue connector behind fuse panel
Door Lock Green/White (-)
Door Unlock Green/Red (-)
At the driver's running board
Door Trigger Light Green/Red (-)
Above fuse panel blue connector
Trunk Pin Green/Black (-)
Steering column
Horn Wire Blue (-)
Steering column
Horn Wire Blue (-)
I highly recommend checking out this killer website. This guy has spent a lot of time detailing some really important car security information.
http://causeforalarm.thecarthing.com...on7/index.html
I was taking a look at this thread....
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-95-civic-power-door-conversion-right-way-tons-pics-end-all-swap-2337026/
an saw this picture...
Is the small grey plug where you can connect the lock/unlock wires to?
I'm not sure, the post wasn't written very well. The sure fire way to tell if that gray plug is what you need is by checking the wires. Are they the correct colors?
ussop
Audio / Security / Video
03-13-2015 11:36 PM
JaySauce
14
04-17-2009 09:56 PM
