Honda S2000 Honda S2000
Retuned. Now running warm and no heat... thermostat??
Old Apr 13, 2009 | 09:01 PM
bseries_ben's Avatar
Default Retuned. Now running warm and no heat... thermostat??
Long story short I recently changed turbos and a few other little things and had my car retuned Friday. Car ran fine and still does but now, 4 days later, car is running warm (now avg. 4 bars going to 5 vs. used to avg at 2 bars going to 3 occasionally if I got caught at a long light or something) and I have no heat. I checked my coolant and the radiator was a little low in the radiator and the overflow was empty. I topped off the radiator and filled the overflow tank a little bit but no dice. I'm thinking thermostat? I am running the modifry unit with my AEM so there's a possibility my tuner changed how many degrees each bar represents but I doubt he would do this without asking or at least telling me he did plus the fact that my heat is gone leads me to believe there's definitely more to it than that but I am going to call him first thing tomorrow morning to verify. I was thinking it might be my waterpump but the car only has 50k on it so I'd be surprised if that was it. Any insight? Thoughts? All are appreciated.
TIA
Ben
Old Apr 13, 2009 | 09:26 PM
dubster99's Avatar
Default Re: Retuned. Now running warm and no heat... thermostat??
Since your heat is gone:
1. Check to make sure fan goes on
2. Bleed coolant system
3. Check thermostat
Do you have another temp gauge besides the one on the OEM cluster?
The heater problem would mean that hot coolant isn't getting to the heater core (blockage, fan doesn't come on, or the heater core is bad.
It seems odd that this happened all the sudden. What exactly did this tuner do? Was anything in the coolant system changed?
Old Apr 13, 2009 | 09:33 PM
Well we capped off some coolant lines because I was going to go from a 35r to a journal bearing turbo that was only oil cooled. I ended up going with a gt3040r so we then put new coolant lines back in so the coolant was drained and refilled. I'm thinking after a little more research it may be an air bubble and/or the thermostat. Since my overflow was empty if the radiator went to suck coolant from the overflow and sucked air instead, that could cause some problems.
annd
1.) fan does come on
2.) doing first thing tomorrow
3.) "^"
Old Apr 13, 2009 | 09:35 PM
dubster99's Avatar
I would assume it's air in the system then. It could be the thermostat, but since the coolant was redone, I'd bleed the system first.
Old Apr 14, 2009 | 09:30 AM
2poor2mod's Avatar
You more than likely have an air pocket in the system that needs to be burped out.
chansta
15
Oct 12, 2010 02:29 PM
Ek9_Cuhzz
Sep 22, 2010 06:30 PM
delsolnewkid
14
Feb 6, 2009 11:36 AM
Tomek
May 30, 2003 12:39 PM
Brett-Pac
Jan 30, 2003 12:43 PM
