bogs and idles at start up... help plz...
Old Apr 8, 2009 | 02:30 PM
crxboy909's Avatar
Default bogs and idles at start up... help plz...
when i would start my car up it bogs but dont die out it just idles really bad like at 100rpm or 200rpm anybody know what the promblem is???? i checked the dis. cap sparkplugs rotors and i cant figure this out....
Old Apr 8, 2009 | 02:31 PM
keemosaki's Avatar
Default Re: bogs and idles at start up... help plz...
CEL? bad idle air control valve? fast idle valve? vacuumn problem?
Old Apr 8, 2009 | 02:33 PM
crxboy909's Avatar
yea a friend of mine sugested the iacv too and i cleaned it out and reinstalled it and its still does it... and when i cruise i get a cel... but my friend said its the o2 sensor
Old Apr 8, 2009 | 03:18 PM
da_ska's Avatar
heres a link u might wanna check out,http://www.superhonda.com/forum/f55/...5/#post2894634
Old Apr 8, 2009 | 03:51 PM
Former User's Avatar
If you let the engine idle until it warms up, does the idle improve? If you push the throttle pedal, does the engine run smoothly or does it run rough?
Old Apr 8, 2009 | 04:09 PM
93egSLEEPER's Avatar
a bad o2 sensor will make your car run like crap through and through. also how is your ilde screw on the TB adjusted?
Old Apr 11, 2009 | 12:46 AM
crxboy909's Avatar
when i take off it does runs rough
crxboy909's Avatar
the screw on my tb should be good cause its a new tb
Old Apr 11, 2009 | 08:21 AM
You might want to check the ignition timing with a timing gun. Make sure to jump the service connector during the procedure. With the engine warm and idling, the pointers should align with the red mark (middle in group of three) on the crank pulley.
Old Apr 12, 2009 | 12:21 PM
crxboy909's Avatar
ok i think u just might have found my problem... i cant believe i didnt think about the timing lol
Platinum.Skillz
Sep 28, 2007 03:33 PM
Smith Wise
Sep 17, 2003 01:32 PM
SpoolnG2
Jan 8, 2003 09:13 AM
b16vteccx
Mar 22, 2002 06:16 AM
