High Idle?? Why?
Old Jan 8, 2003 | 07:35 AM
SpoolnG2's Avatar
Default High Idle?? Why?
i have a 70mm TB from inlinefour.com now when i start the car in the morning, it is pretty good..then i drive it and it idles at like 2k after its warmed up. now if i shut the car off and turn it back on, then it will idle at 1500rpm. theres no vacuum leaks,i have tried adjusting the idle screw. whats wrong? could a bad 02 sensor cause this?? anyone?
Old Jan 8, 2003 | 09:13 AM
BudaKai's Avatar
Default Re: High Idle?? Why? (Jtsintegra)
Bad o2 would cause it to run in open loop. You've posted this before haven't you? I'm thinking about it... Maybe someone else can figure it out.
dc4teg95
Jul 5, 2010 08:09 PM
z6hatchboy
Feb 7, 2008 01:28 PM
boostinjdm
Jan 7, 2007 11:26 AM
turbotime
Oct 24, 2005 12:01 PM
sushibug
May 1, 2002 12:35 PM
