gotta replace b18 LS pistons due to nos.any ideas? on compression
Old Aug 14, 2002 | 06:21 PM
turboex's Avatar
Default gotta replace b18 LS pistons due to nos.any ideas? on compression
Ok the pistons are gone and block has to be honed and bored. still wanna run nos kit 50shot and need new pistons. what do you guys recomend? should i go with higher compression while im in there? what compression can i go with without worrying about the valves hitting? also i can only get 92 octane gas. thanks for the help
[Modified by turboex, 3:21 AM 8/15/2002]
Old Aug 14, 2002 | 08:12 PM
paulzy's Avatar
Default Re: gotta replace b18 LS pistons due to nos.any ideas? on compression (turboex)
10:1 SRP or wisecos
Old Aug 14, 2002 | 08:38 PM
PrecisionH23a's Avatar
usually with forced induction you want to run lower compression
Old Aug 14, 2002 | 11:09 PM
turbo craig's Avatar
Default Re: gotta replace b18 LS pistons due to nos.any ideas? on compression (GudeH23a)
ya except for nitrous oxide u wanna run higher compression
Old Oct 29, 2002 | 09:11 AM
blufke's Avatar
Default Re: gotta replace b18 LS pistons due to nos.any ideas? on compression (turbo craig)
usually with forced induction you want to run lower compression ya except for nitrous oxide u wanna run higher compression
bringing this back from the dead, but that doesnt make any sense to me. with a small shot like 50 its not a big deal but with any FI its just safer for tuning etc to be lower. high is good but doesnt give you as much leeway. correct me if im wrong.
Old Nov 7, 2002 | 10:55 AM
94hondaLS's Avatar
Default Re: gotta replace b18 LS pistons due to nos.any ideas? on compression (blufke)
if you plan to add anything to the a/f ratio its best to go with lower compression. with nitrous or any foced induction you should retard the timing also. with nitrous you should retard 1 degree for every 20hp shot you use.
H23civichatch
Apr 28, 2009 06:51 PM
lsvtechatch92
May 10, 2006 09:39 PM
boosted k20
Jul 26, 2005 07:46 PM
carlos11
Jul 18, 2005 01:53 PM
h22squeaker
Jun 12, 2003 12:04 PM
