gotta replace b18 LS pistons due to nos.any ideas? on compression
Ok the pistons are gone and block has to be honed and bored. still wanna run nos kit 50shot and need new pistons. what do you guys recomend? should i go with higher compression while im in there? what compression can i go with without worrying about the valves hitting? also i can only get 92 octane gas. thanks for the help
[Modified by turboex, 3:21 AM 8/15/2002]
Re: gotta replace b18 LS pistons due to nos.any ideas? on compression (GudeH23a)
usually with forced induction you want to run lower compression
Re: gotta replace b18 LS pistons due to nos.any ideas? on compression (turbo craig)
usually with forced induction you want to run lower compression ya except for nitrous oxide u wanna run higher compression
Re: gotta replace b18 LS pistons due to nos.any ideas? on compression (blufke)
if you plan to add anything to the a/f ratio its best to go with lower compression. with nitrous or any foced induction you should retard the timing also. with nitrous you should retard 1 degree for every 20hp shot you use.
