turbo gsr a/f ratio problems, high idle
Old Apr 5, 2009 | 09:36 PM
aziraco47's Avatar
Default turbo gsr a/f ratio problems, high idle
lately ive been having problems with my car..after it warms up it still idles high between 1500-2000 rpm..also my a/f gauge goes from rich to lean back and forth while in idle and driving..i have apexi vafc..has t3/t4 garrett turbo..external deltagate turbonetics wastegate..str intake manifold..str fuel rail..rc injectors not sure of rating..greddy blow off valve..fluidyne radiator..im pushing about 12 lbs of boost..maybe i have to get it tuned?..if i need to give more info let me know cuz i need this problem fixed..thanks everyone.. i am also new to this forum..
Old Apr 5, 2009 | 09:44 PM
HiProfile's Avatar
Default Re: turbo gsr a/f ratio problems, high idle
Want to provide some setup info, or do you really want us to take shots in the dark?
If so, I'd say massive intake leak. FYI chances are its a narrowband gauge, and they are less useful than a burst aorta.
Old Apr 5, 2009 | 10:01 PM
aziraco47's Avatar
updated post..thanks
Old Apr 6, 2009 | 12:54 AM
jfoster's Avatar
What brand wide band are you using?
Did you just get it together and this is how it runs? Or it ran better before this?
Checked for vacuum leaks? Cleaned IACV?
Old Apr 6, 2009 | 12:04 PM
aziraco47's Avatar
im not too sure on the wide band..i got the car like this.. i saw the previous owner did not know much about cars so i had to get her out of his hands..im hoping to run this car like a factory turbo car..i checked for vacuum leaks none..its running lean now but i still smell excess fuel like its running rich and theres black smoke coming out of my exhaust..maybe the gauge is broken?
Old Apr 6, 2009 | 12:38 PM
inspyral's Avatar
Sounds like you have a narrowband gauge, in which case, bouncing back and forth is normal. As for your idle, barring a vacuum leak or other mechanical problem, you can try turning the idle adjustment screw on your throttle body inward(clockwise) to lower it. The setup should definitely be tuned before you beat on it, especially if the competence of the previous owner is in question. I would also recommend a better tuning solution than an AFC.
DelSolMarine
Oct 20, 2008 03:45 PM
jdmstreethatch
Oct 25, 2006 01:26 PM
swapped95
Sep 17, 2006 12:34 AM
twkdCD595
Aug 21, 2004 02:32 PM
91LSVTEC HB
29
May 26, 2004 12:05 PM
