idle issues
Old Oct 18, 2008 | 07:40 PM
DelSolMarine's Avatar
Default idle issues
i have a built gsr turbo setup. my car was tuned and everything was running fine and for some reason it just started with the idle getting messed up. it still drives fine (a little leaner than before) but when its idling the car a/f is around 16.5-17 and if i hold the switch to make the windows go up and down it goes back to 14.5-15 and as soon as i let off it goes back to 17 again. this seems like some kind of electrical issue. has anyone seen this before? what can i do to fix this?
Old Oct 18, 2008 | 08:05 PM
Default Re: idle issues (DelSolMarine)
just wanted to add that there have been no changes to the tune from before that are making it do this. its just going really lean on idle
Old Oct 18, 2008 | 09:09 PM
StolenTeg's Avatar
My car have a similar problem too, after the tune it was running perfect.
Now it idle all over the place, the idle would surge, it would want to die out, idle at like 1500-2000 rpm.
I think the TPS might went bad
Old Oct 18, 2008 | 09:25 PM
Default Re: idle issues (StolenTeg)
did u fix the tps to determine if that is what is really wrong with it?
Old Oct 19, 2008 | 04:49 AM
bump
Old Oct 19, 2008 | 07:32 AM
anyone?
Old Oct 20, 2008 | 03:32 PM
i am running neptune rtp on my gsr turbo.... what should the eld gauge be reading?
Old Oct 20, 2008 | 03:45 PM
LA_HONDAS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine &raquo;</TD></TR><TR><TD CLASS="quote">i am running neptune rtp on my gsr turbo.... what should the eld gauge be reading?</TD></TR></TABLE>
why not disable it you dont need
turboB16RFD
Oct 9, 2005 09:15 PM
Hyaboosta
Jul 13, 2005 02:14 PM
91LSVTEC HB
29
May 26, 2004 12:05 PM
Tw1n Turb0 Z
Oct 18, 2003 07:23 PM
