New Topic: Easiest B series swap into a 92-95 Coupe?
i have an obd1 motor and it has an obd2 ex motor.. so i guess its obd2 friendly.. so i need a motor that can go right in with no problem (ie: motor mounts, keeping ac, shift linkage..)
no problemo, I`m just busting your *****. Don`t take anything I say too personally, in 6 months you`ll be able to do a little slaying, too
Keep firing away w/ the questions, we`ll do our best
aight then can you give me the specs about the b16a2 or an article about puttin an b16a2 into a 5th gen civic? i need to know what i have to do and where to get it and all the extra parts..
If you swap you will have no problem. A great swap would be the highly torquey b18b ls motor. It is very easy it all lines up and nothing is need. Go for it.
If you arent concerned about smogability, just get a gen1 b16a, fix up the bottom end a bit, and squeeze as much NO2 thru it as possible
NO2 = Best bang for your buck. I have a friend who is running a 70 shot in his SOHC coupe and he can keep up with Z28's all day. $40 to refill your bottle is almost a little too temping! I heard that the Venom kit is good because the NO2 injection is computerized, allowing for a smoother injection into the fuel line and more "natural" power gain as opposed to a huge jolt when the nitrous is injected.
LS is cheap and besides what some people call " A COMPLETE SWAP" you need a bracket or 2. I didnt have the right harness and ended up having to wire vtec for my b16. LS is cheap and with a b16 tranny pretty quick. Thats what i would probably do if i could do it all over. That or just spend the extra dollar(lots of dollars) and get a gsr. BTW buy enuf n20 and you can have a turbo/supercharger and not have to keep refilling it and have it anytime you want as long as you want. Plus it sounds cool.
