quick question about slipstreams...
Will OEM lugnuts work with these? I'm taking them up to the track to put on my car and use for the first time (with some bfg g-force t/a drags), and I don't want to get up there to find out i'm screwed 'cause my lugs won't work.
-Trevor
-Trevor
New User
Re: quick question about slipstreams... (g_man80)
they can be used a temp fix, but I wouldnt reccomend it. its not too safe I ended up buying Gorilla tuner lugs from JC Whitney.
$24.99, comes with the key, 12.5mm I beleive.
If you do use them just be careful torquing them on, you're bound to strip some of the paint of the wheels. i also took off the plastic washers for the time being until i got my new lugs because they tended to keep me from tightening the lug up correctly.
try a search as well
[Modified by Ceeveek, 11:01 AM 8/14/2002]
[Modified by Ceeveek, 7:46 AM 8/15/2002]
Re: quick question about slipstreams... (YumVTEC)
NO!! you need aftermarket lugs that are shaped like this at the bottom \__/. the oem ones are shaped like an acorn, which won't seat in the rim properly.
Re: quick question about slipstreams... (isotopesope)
I secnond that. If you are talking about the lugs for your stock steel wheels they will work, but dont do it. The lugs for steel wheels have a rounded face ( the part that touches the wheel ). If you use those lugs only a small portion of the lug nut will actually be touching the wheel, instead of seating the way it should.
Re: quick question about slipstreams... (ninetfivehatch)
Use the wrong lugnuts and your front wheels have a tendency to fall off.
There are at least 3 people on this board that have had their front wheels fall off from using the wrong lugnuts. Most end up with damage over 1000 assuming they dont actually loose control and crash.
-Trevor
-Trevor
Re: quick question about slipstreams... (deepnite)
Use McGard lugnuts.
The part that grips the threads, and the part that seats against the wheel spin independently of each other, so when the nut goes on far enough to hit the wheel, it stops spinning and just locks against the wheel and squeezes, while you tighten the parts that grips the threads.
That way, you can't scratch the finish of the wheel.
http://www.mcgard.com/automotive/new_prod.asp
[Modified by Mojo-Jojo, 1:33 PM 8/14/2002]
Re: quick question about slipstreams... (Mojo-Jojo)
Sorry, but I have mcguards, and my wheels are scratched all to hell in the lugnut seats. But guess what. When I put the lugnuts on, you can't see it.
Re: quick question about slipstreams... (tonyxcom)
are we talking about the wheel just coming off????
Re: quick question about slipstreams... (brcivic411)
I know a guy who's a Ford mechanic and a Honda nut. He was looking around one day and found that Ford Aerostar lugs fit perfect for his Slipstreams (H22 hatch) and they look really sweet too. They are open end, very low profile, and look exactly like those really expensive black ones but they aren't black.... I'm getting Slipstreams soon and I'm going right to the Ford parts counter to get my lugs...
Re: quick question about slipstreams... (Fabrik8)
dude, ford will prolly charge you just as much as how much a good set of kyokugens cost. how about u go to a junk yard im sure you can find um for a better price
Skeletor
12
02-22-2003 08:14 PM
Sohc Driver
16
06-04-2002 11:09 PM
