B16A2 Swap
Re: B16A2 Swap (uo959)
Everything. you are going from D to B. and the car you have is OBD1 and the motor you want is OBD2 ...Well in the states. If you get a JDM motor then you could leave it OBD1.
https://honda-tech.com/zerothread?id=131949
info is for the 92-95 civic but its the same idea, except its even easier for you because both your car and motor are obd2.
my bad. you are right ODB follows the year not the engine. i do not know alot bout the D engine but as far as the swap goes. know you got to swap everything... engine, trans, ECU. I do not know if the mounts for the b are the same as the D in that model but i bet they are not so mounts too. is the car you have auto or stick? also what year is the motor? the 2gen JDM B16a(92'-95') is OBD1 and the USDM 2gen B16a (99'-00') is OBD2
Re: (Urugly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ballerchild »</TD></TR><TR><TD CLASS="quote">the b16a2 is from the 99-00 em1, which means obd2a!!</TD></TR></TABLE>
actually its ob2b
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Urugly »</TD></TR><TR><TD CLASS="quote">yup yup..if it was a b16a3 then it would be a OBDI from the older del sols. B16A2 came from the newer SI's which are OBDII already.....</TD></TR></TABLE>
thank you for giving correct information.
actually its ob2b
reyrey2006
02-13-2009 08:26 PM
STEV3-O
12
05-31-2004 10:25 AM
