d15 and d16 head studs
Old Apr 1, 2009 | 06:36 PM
The93egg's Avatar
Default d15 and d16 head studs
Ok so i ordered some arp d15 head studs because i stripped my stock ones. It took like a month to get here, and now the box says Honda D-16 10mm SHK. part number 208-4301. Will these fit the d15. I hope the label is wrong or something, I cant send them back to this crap seller.
Old Apr 1, 2009 | 07:12 PM
The93egg's Avatar
Default Re: d15 and d16 head studs
bump
Old Apr 1, 2009 | 07:19 PM
CivicSpoon's Avatar
They are the right ones. They fit the '88-'95 D-series.
Old Apr 1, 2009 | 07:36 PM
The93egg's Avatar
Thanks man, can anyone else verify. Sorry, but i dont wanna attempt to use them and not work in case i have to sell them.
Old Apr 1, 2009 | 08:54 PM
boost and bass's Avatar
the block is the same its the rotating assembly that is deifferent
Old Apr 2, 2009 | 05:28 AM
The93egg's Avatar
What do you mean by that?
Old Apr 2, 2009 | 06:22 AM
j0keefe21's Avatar
he means the crank rods and pistons are whats makes the difference between the d15 and d16. the head studs are exactly the same bc they are the same blocks.
Old Apr 2, 2009 | 06:49 AM
MonkeyMagic's Avatar
could be right
if they are for a vtec they are wrong.
correct me if i'm wrong but i think the non-vtec ones are all the same length. vtec motors have a couple longer studs
Last edited by MonkeyMagic; Apr 2, 2009 at 06:50 AM. Reason: its been a long time since i've seen a d motor
Old Apr 2, 2009 | 07:42 AM
CivicSpoon's Avatar
^ Nope, they're the same. The '96-'00 D-series engines on the other hand have shorter studs than the older ones.
Old Apr 2, 2009 | 08:18 AM
j0keefe21's Avatar
yea i believe if you put a y8 head on a d15 block you need one head stud to be from the y8
iamthefollower
Jul 15, 2011 06:21 PM
IntegraMark
Feb 28, 2007 06:12 AM
19civiclx95
Dec 7, 2005 10:10 AM
1FSTNDN
Jun 22, 2005 07:24 AM
aira
10
Jun 13, 2003 01:12 AM
